Fuel problem
54cj3b
1976 Dj5 258
no fuel at carb
1.) Replaced carb
2.) Replaced filter
3.) Replaced fuel pump
4.) full tank
Ok this is what I get Pump is working fuel flows through filter and out end of fuel line when not connected then I connect line to carb and nothing all vacuum lines are connected to proper ports ect runs great if I pour fuel down carb throat but Im not in to running along side pouring gas in carb while going down the road
Ideas
Help
would be appreciated
thanks
problem solved was a old crudy screen shoved up in the fuel input port
thank god I had a paper clip only thing I had small enough to get in there
