FS: 82-86 CJ-7 Wide Track axles 4.10 gears $385 pr SoCal
RangerRick
FS:
1982-1986 "C" code Wide-Track axle pair, (AMC 20 rear, Dana 30 front) take outs from my 85 CJ-7 with factory open carrier & 4.10 gear ratio. $385 for BOTH front & rear with rebuilt front hubs, (10 miles on them) and new wheel cylinders in the rear. I am including the steering linkage for Wide-Track so these can bolt into any 76-86 CJ-5, CJ-7 & CJ-8. You can convert a narrow track pre 82 to wide track and gain the extra 4" width using the included steering linkage. The rear should have a 1 piece axle conversion done because there is a leaking seal and the end play is not in spec. Other than the leak, the Jeep was a 4 cylinder and mostly stock when I swapped the axles. I will be moving and would rather see someone use these than cart them to my new location. Message me here or IM me if you are interested.
Thanks for reading,
Rick
