M Micah Chambers New member Mar 22, 2012 #1 How do I take it out?? Can I just pull and it pop out or will I have to remove the cover on the housing??
69jeepcj New member Mar 22, 2012 #2 I believe if its non c-clip it should pull out. If c-cliped you will have to pull the cover and take the clip out first. I'm not sure how the newer 30's are set up
Bounty__Hunter Super Moderator Mar 22, 2012 #3 Once the hub is removed, you just pull it out. No clips.
V Vlad New member Mar 22, 2012 #6 I am not sure if you have removed your axle shaft yet but this trick is an awesome way to get that stuck unit bearing out. Unit Bearing - 1
