front drive shaft
Are you asking what model front driveshaft can be cut down to act as a rear driveshaft in your TJ?
He's wanting to upgrade the front driveshaft in his Grand Cherokee from a CV joint to a double-cardan joint.
You'll likely need a shaft custom made unless you're lucky enough to find a Grand Cherokee with the correct length double-cardan front driveshaft. You will also need the transfer case front output yoke from a ZJ, XJ, MJ, or TJ.
