front drive shaft u-joints
extra-medium
I finally got under my jeep today to investigate the sounds i have been hearing when driving. I took the front drive shaft from the t-case to the front diff. out and the u joint closest to the t-case is the culprit. There is like a ball joint in between 2 u joints and the bushing around it has gone out because there is play in it and the ball just moves around inside there. I have been looking and can't find just that joint. Does anyone know what the name of it is? I'm not in a rush since i just finished school today and i work right behind my house, but i was looking to get the new parts installed next week.
p.s.- thank you jeep for making it easy as cake to take the drive shaft out. There are just 8 8mm bolts holding it in.
well another few minutes of searching and i would have found it. its called a double cardan joint, now to find one for a decent price
Gears over in Leigh just off the freeway on the east side can rebuild that Double Cardon joint for ya. They did mine last year for 65$ on my rear drive line.
i heard six states in orem off i15 was pretty good, but they are just parts. I can do the work since i have a press at work and plenty of tools unless there is a specialty tool i need.
