ford 9inch tube question
west747
i have finally got around to stipping this axle down! :D mostly good news. 31 spline axles, 4.10 gears i can sell and the big brakes. however i am not so sure this is the strongest ford 9 inch case. it is very light once everything is out. i guess my question is what is a nodular tube and how can i tell if i have the strong 9inch tube? what should i be looking for?thanks all. chris
haha.... here's a way to tell.... if it is a tube for a ford 9".. it is strong.... the mass is all in the axle shafts and differential... without all that, it is not really too heavy.. just hollow tubes from a hollow ball
heater motor
lol..what do you mean hollow tube to hollow ball? i just thought that this tube was so light it wouldnt be albe to stand a hit from a rock or something without getting damaged. also i have heard that there is 2 different tubes for the 9inch. one is supposed to be alot stronger and thicker than the other.
9'' are VERY light axles, if it is 31 spline, and not 28 im sure its a heavy duty one.
