Congratulations on getting your license and for having a Jeep! Excellent choice in a vehicle.:shades:
Learning to drive your Jeep in snow is just like learning to drive your Jeep in mud, sand, rock, and on the street. Here's a few thoughts for on the trail.
1. Follow behind someone else for the first few times out. Watch their track and how they handle a situation before you try. If they have experience and they have problems on something, you'll probably have the same problem, but at least you will anticipate it before it gets you.
2. Don't start up anything you are not absolutely sure you can get all the way up.:shock: Slipping backwards down a hill is a common cause of roll overs.:redface:
3. Slow and steady is usually the best approach.
4. Don't go down anything too steep or rugged to get back up unless you know for sure there is another (open) way out.
5. Don't drive where you can't see. Don't top a hill unless you know for sure what is on the other side.
6. Take a shovel and tow strap with you. Chains too, since even Jeeps are sometimes requried to put on chains.
7. Fresh snow may hide frozen tracks and ruts underneath. Your Jeep will want to follow those frozen tracks and ruts, so be prepared.
8. Take a blanket and some food and water with you every time you go offroad. It's a Jeep, not a miracle, and sometimes they get stuck meaning that you get stuck.
9. Jeeps are expensive to repair. So unless you have an endless supply of cash, you'll need to mow a lot of lawns to pay for a bent tie rod, punctured oil pan, etc.
10. Finally, the most important advice is to have a blast. You'll only be 16 once!
