I'm thinking about cutting my fenders for a little more clearance. Anyone done this to their jeep. How much should i trim??? Is there anything I need to do to the paint or anything?
heres how i cut mine, but keep in mind i only cut the front and i plan on running 37's. in the back i just removed the flares and filled the holes with some bondo
That's pretty sharp lookin Mxpx182lit... one question, what did you do about the signal lights that went on the side of the front fenders? I don't see them anywhere! Do you even need them?
Word of advice, if you can avoid using a sawzall, do so! Use a cut off whell on a die grinder or a air cutter. Try to avoid a reciprocating saw, it will cause waves on the sheet metal and will leave a courser cut more prone to rust.
