yes, if you are simply swapping block intake and head, swap everything over from the old motor you should be fine. The accessory drives are different as is the ignition and sensors. the 95 ECM is OBDI and the 97 is OBD II. check you local state though, in my state it is not a smog legal swap to put an older motor into a newer chassis.
