DivineImpressions
*2000 Grand Cherokee Laredo 4.0 engine swap issues with 2004 JGC engine
I recently swapped the engine from my 2000 JGC Laredo 4.0 I6 with a 2004 JGC Grand Cherokee...Issue I'm having is Flywheel WILL NOT spin...I used throttle body from '04 because it had two different connections and used the starter from the '04 (changing plug to battery, as needed) BUT when I try to stay the jeep the starter just keeps spinning without spinning Flywheel... There is also a key With a void thru it on dash display. .. I'm at a loss; I have EVERYTHING connected from my original wire harness to EVERYTHING on new'04 engine But Jeep won't start. please HELP with any suggestions***
