sweetpeet
PoliceMonkey161 said:Your current oil psi gauge should be threaded into the block, so you'll remove that and install a (1/8th inch) nipple into the block where your current tie in is, then a tee (1/8th inch) and re-connect the oil line going to the dash. On the branch of the tee you'll install a oil pressure switch (i.e. Holley # 12-810).
Ohh ok I see now
