kent rogers
I'm having trouble with my ebrake system (1975 cj5). It has the foot pedal to operate. I took the assembly out to inspect it because the pedal is very hard to depress and it does not activate the rear drum brakes. When released, the pedal only returns a short distance. I then pull it further up by hand.
I shot some lube into the front cable sheath and freed the cable up, it was very stiff. I can now work the cable through the sheath by hand. I have turned the adjustment up to max, no more threads to tighten.
When I had the assembly out I found there is no spring action to help the pedal come back up when released. Is there supposed to be a spring in the assembly to do this??? The only assist to spring back is the spring wound around the front cable on the end down by the equalizer.
I am assuming most of this type of assembly works the same, Jeep or not. I was hoping one of you members may have dealt with this type of assembly and know if there should be some assist spring on the pedal.
Next I will go into the rear brakes and see what's going on in there but hoped to verify this doubt about if the assembly is okay.
Thanks...….
Thanks...….
