DYNATRAC TRAIL SERIES 60 SF REAR AXLE shipped to lower 48 US
Allen's Offroad
Labor day sales event! Order now through 5pm Labor Day and get your axle shipped for these prices (lower 48 US on this sale). Prices do not include applicable sales tax.
Standard Equipment:
* Complete custom Trail Series 60 semi-float rear axle assembly with 12 month unlimited mileage warranty
* Custom machined Pro Series reverse-cut heavy duty nodular iron housing
* Dual Sump / High Volumeâ„¢ High-Pinion Angle Oil Modification (18 degree max pinion angle)
* Stock axle width (YJ/XJ/TJ = 60.5” or JK = 65.5”) and offset
* Stock pinion angle
* 35 spline, 1½” Diameter, 1 ton heavy duty semi float rear axle shaft assemblies
* 9¾” Ring Gear Diameter
* Choice of ring and pinion ratio
* Steel heavy duty differential cover
* Input yoke - 1310 (U-bolt style)
* Brake tabs welded in place
* Explorer disc brake assemblies with parking brake
* Wheel bolt pattern - 5x4.5”, 5x5”, 5x5.5” (6x5.5” = add $199.00)
* Billet steel housing ends
* Large tapered roller axle bearings
* Heavy duty steel axle retainers
* Axle is finely detailed and painted Dynatrac’s signature gloss black
Finished Dynatrac Trail Series Assemblies and prics:
* Jeep YJ or XJ w/Detroit (Clean Tubes) $3,694.00
* Jeep YJ or XJ w/ARB (Clean Tubes) $3,890.00
* Jeep TJ w/Detroit Dynatrac HD TJ Brackets Std - (excludes some Skyjacker kits) $4,144.00
* Jeep TJ w/ARB Dynatrac HD TJ Brackets Std - (excludes some Skyjacker kits) $4,340.00
* Jeep JK w/Detroit Dynatrac HD JK Brackets Std, ABS retro Std (excludes some Skyjacker kits) Customer to bolt to existing brakes $3,649.00
* Jeep JK w/ARB Dynatrac HD JK Brackets Std, ABS retro Std (excludes some Skyjacker kits) Customer to bolt to existing brakes $3,845.00
Other options are available. Please email with any additional changes or options wanted.
Thank you very much! I am grateful for your business.
Allen
Great deal on these rear ends. PM or post to get one under your rig.
Thank you! I am very grateful for your business.
Allen
