Allen's Offroad
Allen's Offroad is now offering FREE SHIPPING on the Currie Enterprises RockJock Dana 44 Front Axle. This axle housing is totally beefy! Larger tubes and thicker walls than the factory D44 in the Rubicons. Limited time offer - Free HD Steel diff cover or 50% off choice of RJ D44 diff cover.
Download the RockTalk Newsletter here for additional information.
Item #: TJ-44HPF2
Price: $1995.95 shipped in the lower 48 US. CA residents add 7.5% sales tax
Description:
The Currie RockJock® high pinion 44 housing is an all new, heavy duty 44 made 100% by Currie. Our casting is a heavy duty, ductile iron piece that uses the larger JK high pinion 44 gears only. These gears feature a larger ring gear than a standard 44 as well as a 29 spline Dana 60 size pinion gear. Tubes are 3" x .375" wall. Axle tube center line to bottom of housing 5.414”.
All new heavy duty TJ suspension brackets are mounted on this housing for an easy bolt in installation and TJ/LJ/XJ/MJ inner C-knuckles are installed. These are completely bolt in housings that require no modification to the vehicle and they provide a much stronger assembly than the factory frontend in these Jeep vehicles. NOTES: Housing accepts high ratio JK style carriers. Housings do not include ball joints, cover, yoke, axleshafts, or outer knuckers out.
Lockers: 3.73 and down carrier
ARB 30/35 spline
Detroit Locker
TruTrac
E-Locker
Gear ratio: 4.10-5.38
Yoke: 1310/1350
Ball Joints: Factory or Synergy Suspension
Axleshafts: 4130 Chromoly or RCVs are an option
PM me your name, billing and shipping address, phone number, email address (for PDF receipt) to order. I will call you for CC info.
Thank you very much. I am truly grateful for your business. When replying please include all previous messages in PM (keeps a running conversation).
Have a blessed and prosperous day,
Allen
Item #: TJ-44HPF2
Description:
ARB 30/35 spline
Detroit Locker
TruTrac
E-Locker
Yoke: 1310/1350
Allen
