Dynatrac D60 "Free Spin" hub kits!
Allen's Offroad
This is an excellent investment for those of you who have non-serviceable front bearing unit. Get in on the fun that everyone else is enjoying!
If your in the market for a "Free Spin" kit, give me a shot at the sale. Great prices.
Allen
Kit Benefits:
1) Increases reliability.
2) Lower cost of ownership – Wheel bearings and seals are dramatically cheaper to maintain, and can be easily serviced for longer life, even under severe conditions.
3) Dramatic increase in axle strength and reliability with 35-spline 1.50” shafts.
4) Simple, bolt on installation. No machining or welding.
5) Maintains stock brakes and ABS sensors.
Ford Free Spin Hub Kits - (Dually Requires Separate Wheel Adapters)
Ford Super Duty Combo Kit '99-'04 (FS kit w/knuckles & cross-over steering pkg) FO60-2X1104-A
Ford Super Duty Combo Kit ABS Add-On FO60-2X2C189-A
Ford Super Duty Combo Kit Dynaloc UPGRADE (replaces Warn Hubs) DT60-3B396-E
Ford Super Duty FS Kit w/ABS (coarse studs) '99-'04 - F250/F350 FO60-3X1104-A
Ford Super Duty FS Kit w/ABS & Dynalocs (coarse studs) '99-'04 - F250/F350 FO60-3X1104-I
Ford Super Duty FS Kit w/ABS (fine studs) '99-'04 - F250/F350 FO60-3X1104-B
Ford Super Duty FS Kit w/ABS & Dynalocs (fine studs) '99-'04 - F250/F350 FO60-3X1104-H
Ford Super Duty FS Kit w/ABS '99-'04 - F450/F550 FO60-3X1104-E
Ford Super Duty FS Kit w/ABS & Dynalocs '99-'04 - F450/F550 FO60-3X1104-J
Ford Super Duty FS Kit w/ABS (both fine & coarse studs) '99-'04 - F250/F350 FO60-3X1104-D
Ford Super Duty FS Kit w/ABS & Dynalocs (both fine/coarse studs) '99-'04 F250/F350 FO60-3X1104-G
Ford Super Duty FS Kit w/ABS, '05-'08 - F250/F350 SRW Only FO60-3X1104-C
Ford Super Duty FS Kit w/ABS & Dynalocs, '05-'08 - F250/F350 SRW Only FO60-3X1104-F
Dodge Free Spin Hub Kits (Dually Requires Separate Wheel Adapters)
Dodge Stage I - '94-'99 2500/3500 - No ABS CR60-3X1104-B
Dodge Stage I - '94-'99 2500/3500 w/Dynalocs- No ABS CR60-3X1104-D
Dodge Stage II - '94-'99 2500/3500 - (35 Spline, 1.5" Inner Axle Shaft Kit & U-Joints) CR60-2X3219-B
Dodge Stage I - '00-'08 2500/3500 w/ABS CR60-3X1104-A
Dodge Stage I - '00-'08 2500/3500 w/Dynalocs & ABS CR60-3X1104-E
Dodge Stage II - '00-'02 2500/3500 - (35 Spline, 1.5" Inner Axle Shaft Kit & U-Joints) CR60-2X3219-A
Dodge Stage II 35 Spline Internals Kit, Open Diff DA60-4236-B
PM or email for the best deals. I am grateful for your business!
Allen
Get your tow rig ready for the winter and next wheeling season. Improved mileage and servicing. Excellent prices on these kits.
Allen
