drivetrain vibration 95 yj
yes , u joints are o.k. i have been told that driveshaft angle is wrong. is it possible to shim the crossmember down ?? i was also told to change the angle of the rear end.
yeah you can get a transfer case drop. it lowers the tcase 1" to lessen the ujoint angle. I dont think you need to rotate your rearend though. You can make your own tcase drop, its just a spacer that go's between your crossmember and the frame.
THANKS FOR THE HELP PAUL. i just left a 4x4 shop that works on a lot of jeeps and they told me lower crossmember 1" and that should solve my problem
THAKS AGAIN
