1051608
It sounds like the sensors were disconnected earlier so you could take the doors off without killing your
battery. If that's the case, reach your hand up behind the dash (if the 97 I have is like the 2000)
behind where the sensor sits. Feel around for a dangling connector. If I remember right, it's a push and
twist fitting... Although it's been four years since I disconnected it.
If the wire is connected, make sure it is fully seated (push, twist, click, something).
If those two options aren't it, look for a switch on the overhead light. Most cars overhead lights have
three positions (I don't have a speaker bar, so not sure about those). The positions are On, Off, and
Door. Yours may be in On. Move it to Door and it should come on when the doors open... HTH
Cooper.
Oh, and a friendly heads up: typing in all caps LIKE THIS usually means you're yelling... [addsig]
