SpikeSpeigel
I recently broke the straps that hold the driveshaft to the diff. In the proccess it also broke the little lip on the receiver on the diff. It broke the lip that holds the u-joint from falling out. So I went to the junk yard a bought another one. No big deal. But then when I came home to swap them out I realized that the large nut that holds it on was different. The driveshaft receivers on the diff. look exactly same but the nut is approximately 1-2mm bigger. Is my new receiver going to work or is it a different size?[addsig]
