Eclektq
Installed a Teraflex rear disc conversion kit on the YJ. I HIGHLY recommend checking out others before going with this one. Had to grind the calipers down so 31's on 15 rims would turn without binding and low grade quality on fittings etc. I got everything to seal after getting a replacement hardware kit and went to bleeding. Got a hard pedal when not running
but goes squishy once you start it and the booster kicks in, Booster and master are new and work well. I noticed that when we bled the back calipers we'd just get a trickle out of both sides
and the pedal wouldn't go to the floor. The front, Good flow out of bleeders and pedal went to the fire wall. I gutted the proportioning valve and got a little better pedal and performance out of the rear, But it's just not right. I don't want to eliminate the P'valve because I'm told the rears will lock up before the fronts engage. I can only find Disc/Drum proportioning valves on line for a '95 YJ. Anyone know of a P'valve l can cross over to get Disc/Disc specs? All input is appreciated!!
