POWERTRAIN CONTROL MODULE (A) C2 CAV CIRCUIT FUNCTION
A1 - -
A2 F12 18RD/LG FUSED IGNITION SWITCH OUTPUT (RUN/START)
A3 - -
A4 K167 18BR/YL SENSOR GROUND
A5 - -
A6 T41 18BR/LB PARK/NEUTRAL POSITION SWITCH SENSE
A7 K19 18GY IGNITION COIL DRIVER
A8 K24 18GY/BK CRANKSHAFT POSITION SENSOR SIGNAL
A9 - -
A10 K60 18YL/BK IDLE AIR CONTROL NO.2 DRIVER
A11 K40 18BR/WT IDLE AIR CONTROL NO.3 DRIVER
A12 K10 18DB/BR* POWER STEERING PRESSURE SWITCH SENSE
A13 - -
A14 - -
A15 K21 18BK/RD INTAKE AIR TEMPERATURE SENSOR SIGNAL
A16 K2 18TN/BK ENGINE COOLANT TEMPERATURE SENSOR SIGNAL
A17 K7 18OR 5 VOLT SUPPLY
A18 K44 18TN/YL CAMSHAFT POSITION SENSOR SIGNAL
A19 K39 18GY/RD IDLE AIR CONTROL NO.1 DRIVER
A20 K59 18VT/BK IDLE AIR CONTROL NO.4 DRIVER
A21 - -
A22 A14 14RD/WT FUSED B(+)
A23 K22 18OR/DB THROTTLE POSITION SENSOR SIGNAL
A24 K41 18BK/DG UPSTREAM HEATED OXYGEN SENSOR SIGNAL
A25 K141 18TN/WT DOWNSTREAM HEATED OXYGEN SENSOR SIGNAL
A26 - -
A27 K1 18DG/RD MANIFOLD ABSOLUTE PRESSURE SENSOR SIGNAL
A28 - -
A29 - -
A30 - -
A31 Z12 14BK/TN GROUND
A32 Z12 14BK/TN GROUND
POWERTRAIN CONTROL MODULE (C) C1 CAV CIRCUIT FUNCTION
C1 C13 18DB/OR A/C COMPRESSOR CLUTCH RELAY CONTROL (EARLY BUILD)
C1 C13 20DB/OR A/C COMPRESSOR CLUTCH RELAY CONTROL (LATE BUILD)
C2 - - (EARLY BUILD)
C2 C27 18DB/PK RADIATOR FAN RELAY COIL FEED (LATE BUILD)
C3 K51 18DB/YL AUTOMATIC SHUT DOWN RELAY CONTROL
C4 - -
C5 - -
C6 - -
C7 - -
C8 - -
C9 - -
C10 - -
C11 - -
C12 A142 18DG/OR AUTOMATIC SHUT DOWN RELAY OUTPUT
C12 A142 18DG/BK AUTOMATIC SHUT DOWN RELAY OUTPUT(LATE BUILD, W/O DRL AND ABS)
C13 - -
C14 - -
C15 K118 18PK/YL BATTERY TEMPERATURE SENSOR SIGNAL
C16 - -
C17 - -
C18 - -
C19 K31 18BR FUEL PUMP RELAY CONTROL
C20 K52 18PK/BK DUTY CYCLE EVAP/PURGE SOLENOID CONTROL
C21 - -
C22 C22 18DB/WT A/C SWITCH SENSE
C23 C90 18LG/DG A/C SWITCH OUTPUT
C24 K29 18WT/PK STOP LAMP SWITCH SENSE
C25 K72 18DG/OR GENERATOR FIELD SOURCE (+)
C26 K226 18DB/LG FUEL LEVEL SENSOR SIGNAL
C27 D21 18PK SCI TRANSMIT
C28 D2 18WT/BK CCD BUS(-)
C29 D20 18LG SCI RECEIVE
C30 D1 18VT/BR CCD BUS(+)
C31 - -
C32 - -
POWERTRAIN CONTROL MODULE (B) C3 CAV CIRCUIT FUNCTION
B1 - -
B2 - -
B3 - -
B4 K11 18WT/DB INJECTOR NO.1 DRIVER
B5 K13 18YL/WT INJECTOR NO.3 DRIVER
B6 K15 18PK/BK* INJECTOR NO.5 DRIVER
B7 - -
B8 - -
B9 - -
B10 K20 18DG GENERATOR FIELD DRIVER (-)
B11 T23 18OR/LG TORQUE CONVERTOR CLUTCH SOLENOID CONTROL
B12 K16 18LG/BK* INJECTOR NO.6 DRIVER
B13 - -
B14 - -
B15 K12 18TN INJECTOR NO.2 DRIVER
B16 K14 18LB/BR INJECTOR NO.4 DRIVER
B17 - -
B18 - -
B19 - -
B20 - -
B21 - -
B22 - -
B23 G60 18GY/YL OIL PRESSURE SENSOR SIGNAL
B24 - -
B25 - -
B26 - -
B27 G7 18WT/OR VEHICLE SPEED SENSOR SIGNAL
B28 - -
B29 - -
B30 - -
B31 K6 18VT/OR 5 VOLT SUPPLY
B32 - -
