jbxx
I have a couple of questions about the Dana 300 transfer case.
(1). after removing the shift rails and forks there are two "pills"
and two sets of springs and poppet ball bearings that fall into detents in the rails. The two springs are slightly different, one is slightly larger and longer.
I was not carefull enough on the dissassembly, which spring goes in which
hole? Does it matter( I assume that it does)?
(2). Could someone give me the dimensions of the shift rails protruding outside of the case for the different gear positions? e.g. 4L,4H.N,2H.
Thanks!
J.B.
Thanks!
J.B.
