dandoc
So the YJ has bad axle seals in the front (Dana 30 w/ vacuum 4wd disconnect). I've read some online write-ups on how to replace them using some threaded rod, large washers and/or large sockets, mallets, and other various hand tools. I have the new seals (have had them for some time), but never got around to installing them myself, or with a friend. The quote for $360 from a repair shop is a bit much, even though they came down from $525. The seals likely tore when I either removed or re-installed the axle shafts early last summer. The passenger side has a definate leak, the driver's side leaks every so often.
Has anybody on this forum replaced their own axle seals? What difficulties, tips, warnings, etc., can you provide to all of us so that this procedure has less of a chance of being botched by the DIY Jeeper? Stu-Offroad has one of the better write-ups that I've seen. The help is very much appreciated!
