Allen's Offroad
Allen's Offroad is offering the Currie Enterprises CE-9807 (4dr) or CE-9808 (2dr) suspension sytem with Bilstein 5100 shocks for $2174.95 shipped (lower 48 US). If you are in California, well, sales tax is 7.5%.
Also, "JEEPZ Supporting" members get an additional $15 off. That means your next year at JEEPZ is FREE!
Description: The RockJock® JK off road suspension system allows for efficient clearance of up to 37" tall tires (with minor trimming) on any model of the 4 door Jeep JK Wranglers. Kit allows for up to 11" of rear wheel travel and 9 1/2" of front wheel travel when used with the recommended shocks. Up to 11" of front travel is attainable when used with specific shocks and some minor trimming to the vehicle.
This kit is comprised of only the highest end components in the areas of strength, fit, finish, function, and the R&D testing to back them. Included is the set of 8 Johnny Joint adjustable control arms, set of 4 progressively wound coil springs, front urethane bump stop kit, rear bump stop spacers, rear coil spring retaining kit, front D.O.T. approved stainless braided extended brake line kit, rear D.O.T. approved stainless braided extended brake line kit, front trac bar relocation kit, rear trac bar relocation kit, relocation kit for the tops of the front shocks, relocation kit for the bottoms of the rear shocks, front heim jointed adjustable sway bar links for use with the stock front sway bar, rear heim jointed adjustable sway bar extended links for use with the stock rear sway bar, and a dropped pitman arm.
NOTE: 2012 & newer models will most likely require exhaust modifcations to allow for suspension down travel. Add $46.59.
PM me your name, billing and shipping address, phone number, email address (for PDF receipt) to order. I will call you for CC info.
Thank you very much. I am truly grateful for your business. When replying please include all previous messages in PM (keeps a running conversation).
Namaste,
Allen
Namaste,
Allen
