Cooling Problems
daniel19805
I noticed that my Jeep was heating up fairly quickly when i was at a complete dead stop.
I checked the fans & One of them is not moving . It is the radiator fan.
Should this be moving at all times?
Why isnt it running?
1992 4.0 Laredo XJ Cherokee
The electric fan only comes on above a certain temp.
Sure, just throw a switch inline with the switched power to the relay, and replace the relay with a jumper wire. Or route a second switched power feed to the relay and keep the relay intact, if it's working correctly.
It's possible something isn't working correctly or your jeep wouldn't get too hot in the first place. Consider fixing it and you won't need to keep your eye on the guage in order to flip the switch.
