coolant sensor
98 Jeep
I keep getting this warning. I added a anti-freeze additive and a little water and it was OK for a few weeks but the warning is back. I probably have a leak somewhere but where?
check you hoses and connections. check your oil to make sure you haven't blown a head gasket, and check your freeze plugs to make sure they aren't leaking.
It's going in the shop tomorrow, hopefully it won't be too bad. I checked the oil, it was fine. What are freeze plugs, that's probably where the leak is. Is it a bad thing when this censor goes?
