I need to install some 3/4" coil spacers on my 03 jeep.
I dont think its a difficult job however im unsure on a few things. The jeep currently has a 4" lift, when i install them in the rear, i have to disconnect the rear track bar which i think is stock, just curious if after i install these spacers will the track bar still reach after the coil spacers are installed?
Next is basicall the same ? for the front will all the bars hook back up, I currently have JKS disconnects. the steering arms im pretty sure are stock. I do not plan to remove the factory spring isolaters, gonna leave those in and add the 3/4" spacers. Also will I need an alignment?
__________________
__________________
