Cherokee won't start.
A buddy has a 77 CJ7 that has Warn "lock-o-matic" hubs on it. They lock in automatically when you go into 4wd, and you are supposed to get out and turn the dial manually if you are going into 4 low. Don't know how they work or if they are a good design or anything else. I was skeptical, but his 4wd worked with the tcase in 4hi and the dial on the hub not turned, and then he would always turn the dial and go to 4lo when pulling thier boat up the ramp. Gotta get 6 bolt hub if you wanna use them, and i've only seen one set on ebay in the last 6 months and they were in pretty bad shape.
