Tyler Bates
I have an 81 cj5 with a chevy tbi 350 conversion. I have replaced sensors the computer checked timing including base timing and cant track down the problem. When the engine is cold it starts up perfect but wont stay running unless it has an open vaccuum which Ive been unplugging the pcv valve. it also when you rev it up or if your driving and get on the throttle it just cuts out if you release the throttle it will stay running but if you do not it will die.And when the engine heats up it wont run at all starts and dies any suggestions would be much appreciated... thanks
