1040797
Done alot of reading on this, so here goes:
the rear most body mounts have to be "opened up" alittle.
the mounts in front of the rear tires have to be moved (or not used)
The other stuff to think about:
tailgates are different
defroster is inside the windshield of the YJ, but is separate on the CJ
gas tank opening is on the oppisite side
Why do it:
metal is harder than fiberglass
YJs are galvanized
a YJ tub can run around 500-600 dollars, I think fiberglass is around $1500
I've heard fiberglass tubs will always have electrical problems (although I'd think good wiring would overcome this).
In my case, the rear crossmember is rusted through, along with the side body mounts, so they would have to be replaced anyway
Terry[addsig]
