jay79cj7
I took today off work to finally do the herculiner on my CJ. I went to pull it out of the garage to hose it off, and it won't start. It turns over, but doesn't fire. I just got the thing running 2 weeks ago after a total rebuild, but have not had any problems in the short trips I have driven it on and the dozens of start ups.
Its getting air and fuel, no spark. I took a spark plug, held it to ground, and watched for spark as I turned it over. No spark.
I checked all the obvious electrical connections and all seem ok.
The coil is getting power in the start and run position.
I swapped the TFI coil with the old stock coil with no luck: not the coil.
I figured it must be the ignition module. Took it to autozone, had it tested, and it failed "5 out of 6" tests the guy said. Traded $20 for a new one. Still doesn't work.
Pulled out the Haynes, read through it, and decided to check the pickup coil resistance. Its good.
Background on this Jeep: I did a TFI upgrade a year or 2 ago and it has worked fine. I put in a "painless" wiring harness during the rebuild, and now I have a ballast resistor that they provided, which is different from stock. It worked fine for 2 weeks, and there is nothing wrong with it now, I checked.
I cannot figure this out at all. I am stumped and very frustrated that my vacation day is going to waste. Any advice out there?
Thanks in advance.
Thanks in advance.
