ChuginSudz
bchcky
i just saw a picture of your zj in the thread for paragon on 2/22. i was wondering if you got a shot of the front of it? i have a zj too and i'm interested in a bumper for the front end. yours didnt look stock from the side view, if i'm right, let me know what you got. thanks!
It's an ARB Bull Bar. They come in two flavors - winch & non-winch styles.
I have the winch ready model. ARB #3450060
Here are a few older shots of it-
Hope that helps.
-Sudz
air horns
ah yes, thats what i'm looking for, i looked at the ARB bars, but now its just a matter of parting with all that $$$. what you have for a lift on that beast of yours?
hey sudz,
you only need one pole to be "officially fishing" on the beach while you're climbing those sand dunes. :roll: you should have saved the money for all those other poles and spent it on more mods for the rig. :twisted:
by the way keep me in mind next time you guys do a pines run. :wink:
sudz, i was looking at your site, and you have a 3.5" lift on your zj? i'm looking to put a lift on mine and i was just wondering if you had to do any extra work with it as far as lowering the T case or anything of that nature. thanks.
no x'fer case drop is required - a 3.5" lift is not that radical - anything higher & you're looking at adding adjustable track bars (front & rear) & adjustable LCA's. you'll need the LCA's to get your driveline angles dialed back in to avoid (or cleanup) an vibration you may encounter after the lift.
good luck
-Sudz
