Chrysler 8.25
hatemaker22
ok, i'm putting a 8.25 in my 88 cherokee, the only problem i see is that the 8.25 came from an ABS vehicle and my 88 is non ABS. What problems could this give me, and what should i do about them. I was told tha the only thing different in a Non-ABS and an ABS was the caliper. So should i just use the old caliper off my crappy dana 35?, thanks
Put the entire 8.25 on, brakes and all, and you'll be fine. You won't have the hook-ups to the ABS but that won't be a problem.
Neither the 8.25 or D35 had calipers in the Cherokee.
Metallica
thanks for the help, i don't know what i was thinking when i was talking about a caliper, the rear is drum not disk, deeerrrrrr. thanks for the info on this.
