I have a 90 258 bored out .60 over and zeroed planed the deck, you should have plenty of room to go over if needed but stick with .60 over if you can, going over increases the compression. By the way the Felpro head gasket will fit a .60 bore, this you will need. You will also need oversize pistons and rings, Have you had them check out the crank that may also need grinding.
