moe_emt
I have a 97 tj w/a 2.5... Intermitten low voltage on dash, alternator checks out fine.. when it shows low voltage (hard to catch) the guage is true to actual voltage tested..All connections are good...Ok, thinking the voltage regulator is in the BCM do I just try a BCM or has anyone ran into any simular problems? Any ideas on where to check???/
Thanks
Thanks
