1069049
Have just bought a second hand Jeep Grand Cherokee Ltd 5.2L V8. Installed K&N filter without a problem, and having done plugs before, tried to get the plug wires off to change the plugs ... trouble is, I can't get the plug wires off.
Chilton manual says "Carefully twist the spark plug wire boot to loosen it, then pull upward and remove the boot from the plug". Top of the plug wire boot twists but the rest doesn't. Can't see the plug for the metal tube that protects it, so I'm stuck. There a trick somewhere, but I can't see it. All tips welcome. :-?[addsig]
