camber on 92 xj problems
1992 xj beast
bought jeep with 3 in lift on it already and 31 in tires. and the camber is very bad and it wears the outside of the tires really bad and way more then the inside of front tires I NEED HELP BED. im very new to jeeps and I need to fix this problem so I can put my brand new tires on because don't want to ruin them
there is no camber adjustment on these jeeps, they are solid axles. you can do castor and toe.
i would check toe
Just a note, wearing the outside of the front tires can also happen from the previous owner hotrodding through turns. Turning to fast will also wear the outside of the front tire s
Like this?
