I was a a stop light the other day stopped , thank God, and as i started to go Bam! Bam! Bam! the Jeep wouldn't move. I pushed it to the side of the road and there it was, my rear drive shaft hanging there like a limp, you know what i mean. So the question is should i go ahead and put on a Slip Yoke Eliminator Kit and get a Tom wood's drive shaft or just replace the U-joints and straps. The drive shaft is a little beat up but not that bad, I have a 4" lift on 33" tires. I have the transfer case lowerd to the angle is not that bad, but i'm thinking i should just go ahead and do the not so expensive upgrade. 500 bucks and a new driveshaft, more ground clearence, and less worries. Or 60 bucks for a new U-joint. I'm hoping to keep this rig for a while and I know I have a lot more to do to it. I try to do as much of the work as I can myself. Any feedback would be aprreciated.
BigJman
1990 Jeep Wrangler
4.2, 5-speed
lifted but pretty much stock after that
BigJman
1990 Jeep Wrangler
4.2, 5-speed
