peterblesi
On the driver side of the transmission crossmember on my 79 CJ7, there are 3 bolts holding it to the frame. 2 of the bolts are broken off (I'm assuming to nuts welded inside the frame).
I'd like to repair the bolts without removing the crossmember.
Anyone have suggestions / experience repairing without taking the entire jeep apart and without using a welder ?
I'm thinking of these options: (1) drilling through the center of the broken bolt and retapping (2) drilling for the next larger bolt and tapping (3) drilling through the broken bolt, continuing the hole through the top of frame and putting in a through bolt with a nut/washer on top of the frame.
Any thoughts ?
Any thoughts ?
