completelyhis
I put a newly rebuilt engine (2.5L) in my 95 wrangler, new water pump, radiator, thermostat, radiator cap, the whole deal, after running for a couple of minutes, it starts to get quite hot, I shut it down at 210-215, but it shows that it would keep going if I let it.
I rechecked the plug gap, its at .035, I confirmed that the timing is ECM controlled, so it's not advanced, but the top and bottom hose off the radiator are getting hot, though the top seems to be more "radiant" heat than actual water heat. I confirmed the coolant resevoir is at "full." The fan's turning good, good mix of coolant, I just don't know what the problem could be. I have a couple of theories:
1. bad rebuild. Not having enough time, I had a VERY reputable shop do my rebuild for me. Maybe they messed it up?
2. air pockets in the coolant system. I tried driving it around, revving (not above 2,500rpm), thinking it would "burp" any air pockets out. no luck.
any ideas?
Thanks,
Ian
any ideas?
Thanks,
Ian
