brake rotor conversion
seminolejoe
Does anyone know what parts can be used to convert a '74 cj (actually a dj, but I think they are probably the same here) front brakes from drum to disc. I was told that an older ford pickup may work. I'll be keeping it a 2 wheel drive so maybe that will make it a bit easier to find parts. The only problem I'm afraid I'll encounter is the steering gear box is mounted on the right side of the jeep. Being a right hand drive and all. Any help here would be much appreciated. Thanks, Joe
