Best Muffler Choice
RedWrang
Ok here we go again with the same ol question. What do yall think is the better sounding choice. Flowmaster or Glasspack or CherryBomb. 258 6 cyl. Carburated [addsig]
1048739
if you want the cheapest go glasspack a little more go cherrybomb only real difference is the red paint job and if you dont mind the extra cash get a flow master the good point ther is you can quite it down a bit depending on the flowmaster you pick. They are all real good. I went with a glasspack and I am very happy. now I wish it was a bit quiter from time to time so I just have to crank the stereo a bit louder hehehe.
If it is to loud you are to old!
Tug[addsig]
1048740
What are you looking for:
Loud? Deep Throaty rumble? Quiet?
Price no object? Cheap way out?
Do you have a rust problem where you Jeep? Need stainless?
Can you install it yourself? Clamp on? Weld on?
Cat back? or just the muffler?
Tag...Your it
1048743
From a previous post:
Posted: Dec 04, 2002 - 11:53 PM
I have a 1989 YJ with a 4.2-6
Several years ago I shopped for exhaust. Just about the time my manifold cracked.
I installed a Borla Header. I needed to customise a few brackets because they wern't designed for automatics, but it was worth the effort.
When I got to the Cat-back, I looked for cost, life expectency, sound (Understanding most mufflers get louder as the wear out) and ease of install. I looked at Flowmaster (to loud for my taste) Gibson (cost and sound) Dynomax Superturbo (I liked the sound "Quiet" and the warranty was also a plus) I looked into "Cat back systems" for a bolt on install. I did my homework and found the correct size "Super Turbo" muffler was about $30.00 on the internet. and having the Muffler Shop replace the pipe was about $50.00.
Done. This was actually less work than installing a system and he used the factory mounts for a trouble free set up.
Posted: Dec 05, 2002 - 07:31 PM
I have a 1989YJ 4.2 I-6 and the stock muffler dimensions were 2" center inlet with a 2"offset outlet. (Drive shaft side) 10 inches wide x 15 ½ long x 4 1/2 deep. With the understanding that increasing the exhaust system increases power I decided to enlarge the pipes to 2 3/4 (Bigger is better, Right?) Well not always. My Jeep performed better on the freeway, at top end, but lost too much power at low torque speeds. This was unacceptable to me. So I made another change.
I installed 2 1/2 inch pipes that was right for me. The final dimensions were 2 1/2center inlets with 2 1/2 offset outlets. (Drive shaft side) The muffler is 10 inches wide x 18 1/2 long x 4 1/4 deep. (This was a little longer, but it fit fine and left it with a quiet sound) (A lot nicer for Rock Crawling out in nature) The Dynomax "Super Turbo" part number is 17733. I purchased it at Summit Racing (800) 230-3030. If you want to see it go to (www.summitracing.com) In the "Enter Summit Part # box put "WLK-17733" and it will take you to their page (Click on the description and it will show you the part). The price was $34.95 and I believe it was also no tax/ no or reasonable shipping.
1048746
I have a hollowed cat with a CB turbo II muffler... $17.... it is not loud at all.... I might replace it with a glasspack... I just have to hope I can still get some scavenging with it
1048749
Looking for bolt on do it myself. Deep rumble throaty sound. Lowest price possible but still a decent muffler. [addsig]
1048755
Has anyone used a Supertrapp muffler on a wrangler? A friend of mine has one on his toyota pickup that he uses for offroading and it sounds pretty sweet... but it runs 100 bucks and up.[addsig]
