I think I have figured out the problem with throwing the bushings out of the bell crank on the clutch. I am going to replace the left motor mount, one of the bolts was almost all the way out. I tightened it but it may have worn the rubber out on the mount. Something is giving somewhere to make the bushings pop out and this seems like a good place to start. I think when the motor torqs to the right it is just enough to make this happen. Just sharing this info in case anyone else has had this problem
