TwistedCU
RE: rear end
My front end is squealing when it's cold. Sounds like a U joint going bad.
I raised the front end, and turning the wheels there seems to be no play when the axle U joints move back and forth. When manualy steer the wheels left to right there seems to be a little play in the side to side motion in the joints. I'm assuming this means they are bad? I can't get anything to make noise when it's sitting.
It's hard to tell whether it is making a popping noise because my coil spring hits the trackbar mount very slightly (will be fixed when I install my new LCA's) and this makes enough of a rattle to drown out other noise.
My questions are:
A. Does it sound like my axle U joints are bad?
B. Can they be changed without pulling the whole works apart, or can I leave the shaft in, the rotors on, etc???
For the record, it's not the brakes. I checked them first.
[edit] I'm in a bind. We're expecting more bad weather and I'm leary to drive it...
My questions are:
