MudderChuck
Every time someone brings up the old auto transmission, you hear alot of noises. A couple of transmission´s, that would take a lot of abuse where the TH350, TH400,and the torqueflight 727.
These transmission´s didn´t really get a bad rep, until after they started with lock up torque converters and got worse when they added overdrive (both make extra heat).
In otherwords they took a good thing and by making it better, messed it up.
The old stick shift, is considered much more reliable. I´ve managed to break alot more sticks than auto´s.
Autos can´t be repaired on the road. I´ve driven hundreds of miles with one gear in an auto.
Auto´s waste gas, OK.
I´ve got a TH350 behind a 350 Chevy (one ton) that´s got 300,000 and change on it, leaks, but still going strong. And I´ve treated it baaaaaaad. Show me a stick with the same miles and I´ll reconsider my oppinion.
I can´t remember how many times, I´ve seen someone go to shift and get stuck, Just that little hesitation, is often just enough to do it. Or loose it, with one hand on the steering wheel and one on the shift lever.
By the way, for you rock crawlers, my TH350 is manual shift on demand and compression brakes just about as good as a stick.
The 999 torque flight isn´t a bad transmission, a little light, with an overdrive, but seems to hold up well, as least as long as your average AX. Maybe the NV4500 is better, then again maybe the 727 loadflight is better than both.[addsig]
