90Xjay
I have had an intermittent "check antilock" light for several weeks now, it comes on when I barely touch the brake pedal and goes out in about 2-3 seconds usually whether I keep the pedal down or let off. Well now it has stayed on but sometimes still goes out on it's own and has also brought the main "brake" indicator light on occasionally.
I checked the fluid and bled the brakes, even though the pedal has always felt fine. I also just adjusted the rear brakes slightly, they were a little loose. I have not helped the problem at all.
I bought the jeep last fall, bone stock and did a 3" with 31" tires. Funny thing: I can lift up slightly on the emergency brake handle and the anti-lock light goes out and somtimes stays off until I hit the brakes again. I hope this is just a sensor or something I can adjust away. Any suggestions please??
