extra-medium
My Jeep has been running fine, no noises or anything until tonight. I went for a short drive since I just replaced my headlights so I could aim them. I pull out of my driveway and get down to the end of the street and make a right turn. Everything is fine then, and I go a block and make a left turn. Just before I make the left i hear a soft clunking sound. I slow down thinking I have something stuck on my wheel and it gets louder. I went down the street to a parking lot and looked at the underside of my Jeep. The rear drive shaft had about a 1/4" play either way which I believe to be normal. There is no evidence of fluid draining out of the rear diff, axle seals, or transfer case. My front drive shaft isn't in because the double cardan joint needs to be replaced. On the way home I shifted the t-case to 4-hi and I heard a clunk like the chain was meshing with the gears inside, shifted back to 2wd and everything was fine. If I go over 20 mph it is there no matter what, but under 20mph it only has a clunking sound if I am coasting. What thoughts does everyone have as to what it could be?
