Another driveline vibration question please help!
rocks9440
I have a 94 xj with a 3 in lift and i have a vibration that seems to only be noticeable above 60mph, i feel it most in the seat not the steering wheel. I removed the front driveshaft and its still vibrates but it only does it when i accelerate, it doesnt do it when i decelerate, also it goes away when shifted into nuetral. Please help
Sounds like a rear pinion angle adjustment problem. Here is a very helpful link: Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
Kevin
Ill probably go ahead and shim it and replace the ujoints. Hopefully that should fix my problem. Thanks for the advice.
