annoying clicking
sebass005
I just bought and lifted a 2000 XJ and have taken it off road a few times already. About 2 months ago I heard a clicking noise down by the wheel everytime I brake and make a right turn. One of my buddies said that my U-Joint could be either worn out or just straight up busted and I was just wondering if anybody else has had a problem similar to that so I can get a second opinion. Also, if it is the U-Joint, would it be very difficult to fix at home or would I have to bring it in? My friend is really good at mechanic work and actually installed a body lift on his Tacoma in his driveway. Any help would be great, thank you.
Sebass
if its when you brake it might be your caliper going, u joints arent hard to replace if you have a few tools, a vice is the most necesarry and will make life the easiest so if it turns out to be a u joint ur lucky, otherwise have fun figuring out what it is because clicking on a jeep can be just about anything, just remember what jeep stands for: Just Empty Every Pocket
the clicking noise adds "character"
fyi - http://www.4x4wire.com/4x4/tech/axle/ujoint/
just did mine 2 weekends ago - this one was bone dry
Hi,
If a U-joint is broken, you'd have more issues than just a clicking noise. :shock:
Worn U-joints, now that's very likely. U-joints are not hard to do. I've changed them without a vice, and it is a tad harder, but very doable. What you REALLY need is a socket set, as the correct sized socket helps alot. You basically set the socket face down on the u-joint caps then smack the socket with a hammer to push the joint out. :mrgreen:
-Nick :!:
Thanks everybody for your advice, I went out this morning and purchased a new U-Joint and my friend and i are going to try to install it tonight. Ill keep yall posted and let you know how it went. Thanks again.
sebass
Need some help, broke the zipper on my rear window......
well, after a few hours of work we got it done and the problem was the u-joint. the clicking is finally gone!!! thought it wasnt too hard of an install, i do recommend using a vice if possible, it would have made the job a lot eaiser.
