JeepsterCJ5
OK I found this at Jeeptech.com....
Identifying the gear ratio of an AMC 20 is a bit tricky. Dana axles normally have a tag on the left of the diff cover with the gear ratio at the time of build. The AMC axles have a code that has to be looked up in a table. The code is stamped on the housing boss to the left of the diff cover right near the axle tube. Good part about the stamp is it tends to stay readable longer than the tag, but you have to know the code. Since there are conflicts between what a code means for a narrow track and what it means for a wide track, don't count solely on the code to identify an axle. Bring a tape measure or know the source of the part.
But I can't find the damn thing.. I'm not sure I am even looking in the right place... the tag is missing (of course) and I'm not even sure what I need to replace... when the tranfer is in @ it tries to move... makes some really rough noises.. and doesn't... is it the clutches?.. do I need new ring and pinion?.. HELP!!!
