UPDATE: got the replacement O2 today (another NTK). Just got done putting in the replacement and took it for a test drive. No spuddering or hesitation. I just got back and parked it. Gonna let it cool back down and take it for another test run. This occurred the first time I replaced the O2 sensor. This time I'm going to test it a second time after cool down
Great to hear it is fixed. That maybe the first time I've heard of a new NTK going bad this quickly.
Good luck going forward.
I spoke too soon. Fired it up this morning and tried to drive it to work. ITS BACK...... I think I'll go with your suggestion regarding the TPS and buy one from AutoZone for $50 (instead of the $8 on Ebay) and see if this whole was caused by a cheap sensor
Thermo hasn't been fixed yet. I'll call the garage to see what they would charge for the labor.
I gave it a few days before responding. I hope that issue is behind you. It boiled down to a bad O2 and temp sensor, introducing a bad TPS and AZ not knowing how to test a battery.
You have probably learned a lot about your jeep from this issue.
You also web crawled doing research and asked others on different forums. Suggestion on researching forums. Read many posts (20-50) and look for a trend in fixes. Common failures are well covered and you'll see trends in fixes. The same with knowledgable members you will see trends.
Biggest thing is describing the issue effectively especially when it changes. Realize I'm blind, deaf, have no sense of touch or smell when it comes to your or anyone's issues. I could only read or view your post as it is presented.
Lastly:
Cheap and easy first and learn how to test some of these components.
Anytime
To add a FSM while pricy goes a long way?
Happy Holidays!
